Was at home with a bad cold today and so obviously couldn't resist popping into the workshop to plan what needs to be done over the next few days or so. Well, you know how it is; one thing leads to another and before long you're 'doing stuff'. Well, today's stuff was a backing 'ring' for the front NACA vent, brackets for holding wiring away from bulkheads as it runs towards the tail end (ELT antenna wire, strobe wires, etc).
I also made a pair of rudder pedal extensions cut from .125" sheet along the same lines as Paul Dye's (in fact, I stole his design, to be more specific: thanks Paul!). I haven't completed them just yet; I still need to take all the holes to #30 and then countersink for flush rivets. Once that is done I shall be seeing about getting the whole pedal assembly anodised a deep blue colour. Should look good with the gold flush rivets and all.
