Jeff & Jackie's RV-8 Project
Date: 10-14-2006
Number of Hours: 1.00
Manual Reference: 7-11
Brief Description: Left flap, dimpling skins
Went over to see Phil as planned. Got the holes on the flap skins deburred and then dimpled any hole on the flap or aileron skins that I wouldn't be able to reach later with a squeezer. It was while doing this that I noticed that I hadn't fabricated the little spacers that sit between the top skin and the bottom of the end ribs. Actually, unlike the RV-7 flap plans (I checked), there is no mention of these spacers at all, which is obviously why I forget when match drilling. And while I'm on the subject of RV-7 vs RV-8; man what a difference! The flap drawing for the -7 is *sooo* much better than the one for the -8. Not only that, but all the ribs are pre-punched as well as the skin, and the brackets are pre-fabricated too! No having to cut them from flat stock. Damn!! Phil's got it easy and I made sure he knew it!! While I was there I gave Phil a small hand putting the vent line and capacitive senders into his tanks, but on the whole we spent most of the time gabbing about stuff, comparing different aspects of -7 vs -8 and complaining about some of the things that really *should* be part of the instructions, especially where unknowledgable first-time builders are concerned, like us. Anyway, after four hours (including a break for lunch) I had my bits done and scooted off home. I need to finish deburring, dimpling, countersinking, edge-finishing, etc, etc all the flap parts and I'll try to do most of these over the coming week. With two exams looming though, I may not be able to devote quite as much time as I'd like. No matter, I'm in no rush...
