Brief Description: Fitting pre-built fuel tank (right wing)
Didn't do much tonight. I'm going away on a training course next week so there's no point busting a gut because I won't be able to finish anything completely. Tonight removed the bottom skins and then match drilled the tank to the main spar and the W-423 joint plate. Then I removed the leading edge since I need to finish installing the bracket for the leading edge light and decide exactly where I'm going to mount the AoA bits. I'll do those tomorrow though. I'm kinda hoping I can get to the point where all the drilling is done. Then maybe, just maybe, if I ask real nice like, Jackie will edge-finish stuff while I'm away. If she did that we'd be able to deburr and dimple holes and then prime the leading edge components and top skins the weekend I get back. We'll see :-)
