Another deburring & dimpling evening. Edge finished the bottom outboard wing skin. Edge finished the three access panels. Dimpled the bottom of the main ribs. Dimpled the bottom of the rear spaer and then 'touched up' with a deburring tool as per instructions. I then decided to read a head a little and ended up temporarily assembling the W-413 and W-414 aileron brackets and sorting out all the rivets. If I don't do the top outboard skin tomorrow then I'll cleco these to the rear spar and make sure every thing is aligned before drilling and then prepping for priming. Hopefully I can get them primed next time I do some priming (this Sunday maybe, weather and skydiving permitting...)
