I noticed the other day that the leading edge skin wouldn't go on properly and I had to take the dremel with a diamond cut-off wheel and a grinding cylinder to the steel angle, and make me a couple of grooves (man!) before I could fit the leading edge. Half an hour careful maneouvering to avoid damaging the spar or main skins! Thirty minutes, job done, onwards and upwards!! :-)
