1) LH side where the intercom is located prior to actual connection to pannel
2) This is the area I chose to have the passthru from engine to cabin, and shows the connectivity of the thermocouple probes for 4 Cylinder head probes and the 4 exhaust gas temp probes. Also shown are the primary battery leads and the other Low voltage/low current wires to and from the cockpit. The holes have yet to be sealed with fire proof goo. that will happen prior to DAR visit
3) A closer view of the RH side of the engive showing routing of oil pressure, battery cables, temp probes and electronci ignition wires.
