JoeNelsens Web Site
Date:  4-26-2014
Brief Description:  ammeter
These two pictures are meant to show the hi range cal.
1) showing actual current indicating 17.7 amp and meter just under 20 amp discharge
2) again, actual current17.0 and meter shows just under 20 amp charge.
When I actually get going with the engine test s I shal revisit this and may want to change scale to 25 amp or 30 amp. I shal see.
the bigish spring is the dummy load to cread the 17 amp current flow.
17 amp discharge
17 amp discharge
17 amp charge
17 amp charge
