1) My most trying times here. I had layed out as the plans suggested for the allignment of the MLG this is RH side with the axel and toe in sleeve in place. The cross bar extends to the LH side in a like manner
2) A rear view of the RH setup
3) the level on the A/C botton longerons to keep check on the levelness of things, and to measure the vertical drop of the axel tip reference point, per plans.
