2) After some discussion on both the blog and with Sonex about pily engine mounts vs Sonex supplied rubber ones, I show here the differences betweem then, and have considered the pily as unsuitabel. these pily items were described as proper on the blog, buth they are not as they lack the depth and diameter of the factory ones. I opted to forget the poly ones and use the rubber ones. the, the rubber ones, may be a maintance item for the future. the poly ones should also fit the big Dodge, or the little Dodge front sway bar link rubber replacement.
