1- almost finished with the strobe. Thois is the first tifment of the entire thing, prior to actually sanding and painting. Not too awfully bad for a first fiberglas project. Boy did I hate to cut that tip fiberglas when I started out!
2--interior shot of glass on the inside.
3-- this shows the plastic tubing I used to run the single twisted shielded cable from the tip to the powersupply to be mounted in the space just below the forward spar of the vert stab.
