JoeNelsens Web Site
Date:  2-5-2017
Number of Hours:  4.00
Brief Description:  getting there!
1) I was told that I had letters too small, so I changed them to 2 inches. Didnt know, but I do now. and that is why one needs others to look at things from time to time!! Thanks John Halterman!
2) Well WEll! Looks a lot better, at least from here! Both sides are initially installed. Top and sides look good enough to continue. But the left side contour for the Aero injector does not match the RH side at all, and will need major work to get it there. Luck would have me in its hand as a really fine fellow is also available to assist with my fiberglassing and has indicated that the big gap on the bottom will sort of correct itself some when I get the lower firewall cut and attached.Clint Murphy is well known to be a fiberglass guy!
experimental!
experimental!
Both sides are on!
Both sides are on!
