JoeNelsens Web Site
Date: 9-3-2016
Number of Hours: 8.00
Brief Description: culmination of many days work
1) Well, this is a mile stone, at least for me!! After almost a week and a half getting to this point...actually installing the pannel...I was pleased! The LH side was a real breeze, but there is still that rats nest of the RH side to actually sort out I took this pix about 3 hours prior to departing for the day, and dosent show in exquisite detail the efforts made in sorting things out. It was enough to actually apply power to it, and everything came on...except for the com radio. I found out that I must have broke something loose when installing things, as the radio did function on the bench. It is not getting 12 volts. May be a switch I broke, defective switch, or just didnt hook things up correctly.( THAT could not be the problem at all!!). Well...maybe! I am current suffering from a medication allergy, and I have been bothered by it for a couple of days, and maybe I didnt pay close enough attention when I was shoving things around. Now thats a better srtory and I guess I will stick to it.
2) To take a break from the creeper duty underneath the plane, I decided to install the antennas. they look straight to me
3) Can you tell if they are straight? meaning inline with the aft top? If you can, you are better than I!! I cant even see the things!!
almost there!!
are they straight?
