1) This shows the after tape removal and final paint. Not too bad once it is all ressed out with red accessories!
2) The other side looks just as good!
3) this is an important picture, should I have future problems. It showe the cam gear alligned properly with the dot on the gear tooth at about 10:30. should work!
Oh, the slot inside is for the oil pump attachment!
