1) one of the first times the pannel has been actually secured in place. there were a few places I had to file to make corners fit, but no concern. Note the ammeter gauge, and the three lights below it. the red, green and yellow lamps are alarm points for the systems buss voltage monitoring. When the voltage falls below 11 volts the red light is on, green is normal between 11.3(?) to 15.1 or so, and the yellow is over voltage, 15.3 and up. Some of the modern electronis displays can not handle 16 volts but the old stuff I have probavbly will do just fine. the comm is old and I have a spare. The Sandia Avionice transponder isnt in hand yet but it will go fron 11 to 28 volts. the rest of the stuf is wide range also.
From the left on the sub pannel, the hole for the throttle, the red mix control, the homemade trim control and the black t handle is the panel mounted fuel shut off
