JoeNelsens Web Site
NELSEN SONEX
ammeter
These two pictures are meant to show the hi range cal.
1) showing actual current indicating 17.7 amp and meter just under 20 amp discharge
2) again, actual current17.0 and meter shows just under 20 amp charge.
When I actually get going with the engine test s I shal revisit this and may want to change scale to 25 amp or 30 amp. I shal see.
the bigish spring is the dummy load to cread the 17 amp current flow.
17 amp discharge
17 amp charge
NELSEN SONEX Home
1349
adjustments after f
avionics
canopy
cowling and fibergla
electrical systems
First flight
flight control syste
fuel system
Instruments
140
MLG
system testing
tail feathers
tail wheel
trim system
weight and ballancin
wings
77
518
