1--The rear access area has the powersupply for the tip strobe---the little can seen. the Bowden cavble shown is the trim system actuating control from the cockpit. Bowden cables are push pull type.
2---All right...its still lying on the right side! But you can still see the connection from the bowden cable to the actual trim tab on the rear of the lh elevator, per plans This tavb is the very first thing I made a couple of years ago, and its finally installed. I am glad I found it!! that is the rudder flipped off to the right side in the bottom of the picture. Maybe one of these days soon I will put the fusealage on the bottom and have a whole new series of pictures to have to do!!
3---This is the tail wheel mechanics and how they hook up to the rudder. I have seen a couple of different ideas for this and they all look fine. I did not have to do any tweaking on this...it fit correctly. And wonder of all wonders, it works great! No binding or twisting at all, end to end. I was really very surprised because, if you remenber, these are all my own delded components. Ha, I guess vbeing able to follow the plans really works out at times!
