JoeNelsens Web Site
Date:  2-22-2014
Number of Hours:  10.00
Brief Description:  gfeneral pictures
1--Here are the v and h stabs in their final resting place, plus 90 deg r wing low!! they all fit pretty well with nominal shims IMHO. for a scratch built aircraft I guess. We shall see. but they are at 90 deg to each other, the rudder travel is on spec, and so is the ele, the latter with a bit more tweaking than I actually thought would be needed.
2--Tail wheel leg is installed, and the wheel assembly is close at hand. and as I write this, it is indeed installed in jinal position
3---Looking forward fro the aft end, showing the ele push rod in place. the supports still have a couple of clecos and need to be finalised as the picture was taken. If one looks closely to the rh side of pix 3 there are rudder cables present...another big step, at least for me!
OK, a bit of an update...as I type this on the evening of 2-27-14, I have done a bit more, but have yet to take pictures. I appoligize for the mess in the shop (in the background) but my only excuse is that I have been busy elsewhere part timeing it at a music store doing electronic repairs. Money is just that...money.As I still need some for this little airplane of mine, I sometimes do just a small thing here and there and befor I know it, a lot has been done, and no pictures. I will attempt to remember to get some really up to date pix and just display them here. thanks for reading!!
Installed
Installed
almost installed
almost installed
moving forward and installing things
