Brief Description: primary wiring of instrument pannel
1--This shows the initial wiring of the ground, +12 volt, and speaker load resistor for the Narco com radio. I found this method very much easier than doing it in the cockpit.
2-- Progress is happeniong, showing primary power getting to the tach and engine monitor via fuses and switches.
3--More of the same type of progress. To the right is the master on off and the starter relay control switch. I have now mounter to the left end of the fixture the master contactor and stareter contactor, and temp wired them to check for activation. The coils of wire are long enough to go thru the firswall to their resepctive targets. Those wires probably will pass thru the RH side of the fire wall, as that is where the battery will be.
