pix 1 this is the table top mount I used to hold the panel for wiring. the stand is from an old flat panel and was modified soas to allow a 90 deg tilt of the inst panel durring actual wiring
pix 2 front side of stand showing un obstructed access to the back side
At this time, I plan to do most of the wiring this way, and leave enough pig tail to reach where I need to go with audio mic and etc.I am not so sure I will also use a modular approach when interfacing to the airframe, using a plug of some sort I hate wiring upside down!!
