JoeNelsens Web Site
Date:  4-9-2013
Number of Hours:  6.50
Brief Description:  axels
pix 1
just finished welding one axel for MLG.It was easy enough knowing a bit about gas welding, and had previously figured out the correcdt angle. It took a smaqll bit of gringing to get the head of the bolt to snugly fit in to the angled endo the tubing. final resule was very acceptable.
pix2
now that it is cold it needs to be cleaned up on the wire wheel. Not difficult, but must be protected from all the little flying wires from the wheel!
pix3
all done except for final paint. spacers made and installed as well as the nuts.
hot off mthe press!
hot off mthe press!
