JoeNelsens Web Site
Date:  3-23-2013
Number of Hours:  5.00
Brief Description:  flap handle allignment
Imageo ne and two after welding the flap handle, I need to also install and allign the aluminum handle to the actuator. I used a neat small laser allignment tool at Harbour Freight Aircraft Tool department (dont you know!) that has a magnetic base . I was able to allign the two end tabs with the center handle pretty close, but not exactly. I felt that the two outer ends were plelnty close, so instead of remaking the thing, I opted to move the handle.25 in so as its front edge was parrellel to the laser beam that defined the end plate rodend holes( whew!).I am pretty sure it will work fine, and if it dosent by the time I get the wings on and alligned, all I have to remake is the handle.
Image three this shows the discrepency.It did take me a bit of head scratching to figure this out, and to be comfortable with it.
flap handle
flap handle
flap handle
flap handle
allignment error
allignment error
