JoeNelsens Web Site
Date:  2-28-2013
Number of Hours:  5.50
Brief Description:  small parts for the push rods
Image one flap handel pieces that need to be welded to the actual tube. Well, most of them will. the two on the left, with the holes, should not have the holes! And after I did a great job of getting that margin on the bottom to perfectly fit the tube. Goes to show what one has to do to realize one has to read the prints correctly!They will be chromed and hung in the shop....maybe!
Image two more flat steel parts for the control assembly that used to be the triangel that isnt a triangle. Gotta find another name!
Image three end plates for several of the systems push rods.
flap handle
flap handle
more control triangle which isnt parts
flap push rod and ends
