Brief Description: Began covering with Superflite cloth
Prepared a 25/75 solution of acetone to poly tak glue. Cut Superflite cloth to fit horizontal stabilizers, elevators, and rudder with wrap around from bottom sides. Applied glue to frames and applied pressure to glued areas in order to attach to frame of each piece. Used covering iron to speed tack process of glue on ends and corners. Reloacated hinge and control horn holes with pencil soldering iro 375 degrees. Loosely tightened fabric over entire area of each piece with larger iron, 375 degrees.
