Fabricated brake lever mount from aluminum tubing and fastened to existing seat bolts on cross braces. Drilled longeron braces on lower right hand fuselage to accept grommets for brake lines along front to back. Installed grommets, brake lines and master cylinders with handle. Connected lines to master cylinders and slave cylinders. Zip tied in place. Injected brake fluit from lower slave cylinder bleed fittings upward to master cylinders and bled system. Function checked. Zip tied brake lines to eliminate chaffing and to gear legs.
