Brief Description: Applied seam tape to tail surfaces
Marked area on both sides of tail surfaces to be covered with seam tape using a straight edge, and a pencil. Began applying 2 inch seam tape to both sides of horizontal stabilizer, elevators, and rudder where center brace attached to leading across to trailing edges. This was accomplished by applying poly tack over entire area, applying tape, and working glue into tape with fingers, followed by sealing down with an iron. Began applying 3 inch seam tape around the perimeter tubes of each piece securing it in the same fashion.
