This mod will protect the inner wheel hub from saltwater corrosion. Mount grease nipple at the end of the spindle and drill out a 1 mm hole between the bearings in the wheel hub. I also removed the inner tube to make the wheel tubeless using the tubeless kit. This mod also makes the main wheels more rigid and stiffer.
