JON'S WEB SITE
Date:  8-5-2016
Number of Hours:  5.00
Manual Reference:  4.010
Brief Description:  Sweep cables routing in the wing
Manual says the sweep cables has to go over the compression strut and under the aileron torque tube. This is due to if the the cables goes under the compression strut then there will be contact between the fabric and cables on the wing underside, (ref Kerry R.). To prevent chafing on the aileron torquetube I used a ziptie to give the necessary claring
