JON'S WEB SITE
Date:  10-18-2005
Number of Hours:  1.00
Manual Reference:  NA
Brief Description:  Treatment with lensoil on inside tubings
I used cold pressed lenseoil unboiled as a test to se how it is in use as protection on the inside of tubings. I used a cheap spraycan and pressurized air. I also pulled a cloth trough the tubings after spraying to even out the oil.
After 4 days it is still not completely dry. Next I will use boiled oil, to see if it will dry faster.
Lensoil
Lensoil
equipment
equipment
