Maybe I`m the first searey-owner to use Oratex fabric system. Its a friendly material to work with. No hazardous fumes, waterbased glue, heat activated after it is completely dry, strong bond, temperature independent after it has dried, easy to repair, collor covered from factory means no aditional painting or spraying. Apply hotmelt adhesive on structure to be covered and to backside of the fabric. Two layers, dries completely within two or three hours in room temperature, then you can decide when to apply heat for bonding. Using heatgun or iron.
