JON'S WEB SITE
Date:  7-7-2016
Number of Hours:  5.00
Manual Reference:  NA
Brief Description:  Modifying main wheels
This mod will protect the inner wheel hub from saltwater corrosion. Mount grease nipple at the end of the spindle and drill out a 1 mm hole between the bearings in the wheel hub.
I also removed the inner tube to make the wheel tubeless using the tubeless kit. This mod also makes the main wheels more rigid and stiffer.
