Ron's Web Site
Date:  5-16-2008
Brief Description:  Fuel Lines 4
I fabricated the-6 fuel line which runs under the pilot's feet and runs up to a steel bulkhead at the firewall. Fiberglass insulating sleeve was placed around the tubing to avoid picking up heat from the exhaust tunnel. A -4 fuel line is tee'd up to a manifold where the fuel pressure sensor is mounted and a 90 deg fitting which will supply fuel to the primer.
Insulated main fuel line and primer/pressure sensor takeoff.
