I installed fused connector cables to the Auxiliary and Main Batteries, and constructed a "Y" or parallel cable so as to enable plugging both batteries in to a Battery Tender Plus unit. Aviation Consumer rated these devices as superior for desulphation, which preserves maximum battery efficiency. I plan on trickle charging the aircraft battery when the Bearhawk is hangar-bound.
