It's hard to believe it took 2 hours to run these wires (20 guage), but it did! I wanted to put the wire exit as close as possible to the center of rotation, but the curves were pretty difficult to pass the wire. I ended up using welding rod with hooks on each end, and pushing and pulling, to get the wire around the sharpest angle. A borescope came in handy to hook the two hooks.
