Ron's Web Site
Date: 7-31-2010
Number of Hours: 4.00
Brief Description: Windshield Bottom Fairing 1
There is a considerable gap, perhaps 1.5 inches, between the bottom of the windshield and the boot cowl just in front of the post. I toyed with the idea of using modelling clay to fill that in, but that is a tedius process, and basically messy. I ended up using some .005 stainless steel which I'd bought at the Kelley AFB surplus store over a decade ago, which I trimmed fill in the gaps, both aft at the post and also along the front of the windshield. These strips were held in place with electrical tape. I used some cloth to get the overall contour for a template, so hopefully, the actual fiberglass application would more readily fit. I ended up using 6 layers of medium weight fiberglass, which was testing the pot life of the epoxy. After curing, I then marked out the desired trim lines using electrical and masking tape, using a 1.5 inch upper dimension and a 1 inch lower dimension.
Gaps filled in with thin .005 inch strips of stainless steel.
Cutting Medium Weight Fiberglass using cloth template.
Fiberglass cloth epoxied in place, tape aligned with trimming lines.
