Ron's Web Site
Date:  7-2-2010
Number of Hours:  8.00
Brief Description:  Gear Fairing 1
Apparently I was too generous with cutouts for the brake line and the fuselage-gear framing, and a single piece of aluminum wouldn't cover up the holes. So, I decided to make a fiberglass fairing, which would allow me to better contour the fairing to the fuselage. I initially cut out a poster template and then transferred it to .016 aluminum. The design condition for the fairing is cruise, which means the gear is unloaded. In order to accomadate that condition, I jacked up the fuselage so the wheels were off the ground. To bridge the gap inboard, I cut out a teardrop shape and gently bent it to fit. I tapered the aft end of the fairing using modelling clay, and used electrician's and tent repair tape, as well as a hot glue gun, to secure the aluminum on both gear, and after masking off the area, glassed in three ply's with epoxy.
Outboard view of mold.
Inboard view.
Inboard view.
Fiberglass and epoxy layup.
