Located the ammeter shunt next to the master cut-off switch in the lower panel. Cut and drilled copper buss bar stock to connect the circuit breakers. Routed 12 AWG wire to the shunt. Placed the lower panel in the aircraft and trial fit the myriad of wires to visualize the best way to route them.
