JOHN'S WEB SITE
Helicycle
Turbine engine
2-3-2013
Oil strainer
Created a brass oil strainer which should filter large foreign objects from the lubrication system.Used JB Weld to secure filter to AN fittings. Placed strainer assembly into sump with Tite-Seal sealant.
Components
Final assembly
Inserting into sump
F1 Rocket Evo Home
Helicycle Home
1065
Cabin Doors
Check-out and Airwor
Governor & RFI
Main Transmission
Rotor Blade
Swashplate
Swashplate
Tail Rotor
Trim Fins
Turbine engine
25
83
