Soldered four wires to pins on the 90 deg. electrical fitting Used marine grade heat-shrink to secure solder joints.
Cut a V- shaped slot around periphery of sensor to receive epoxy sealant. Reports from other builders suggest the sensors are leaking oil in service. Placed JB weld to seal sensor end.
