Routed oil lines on engine. Installed oil sump. Preliminarily fitted flexible hose to oil filter, which will allow filter changes without distorting rigid lines(copied from Tim Drnec). Started work on oil pressure sender mounted vertically with Hobbs switch as installed by Mike Smith.
