JOHN'S WEB SITE
Helicycle
Tail Rotor
6-11-2011
Tail rotor drive shaft
Measured and cut tail rotor drive shaft tubes. Drilled locator alignment holes after shaft was verified to be true in vertical and horiz. planes.
Drilling 3/16" holes
connect bearing to shaft
alignment holes
F1 Rocket Evo Home
Helicycle Home
1065
Cabin Doors
Check-out and Airwor
Governor & RFI
Main Transmission
Rotor Blade
Swashplate
Swashplate
Tail Rotor
Trim Fins
Turbine engine
25
83
