JOHN'S WEB SITE
Date:  8-31-2013
Number of Hours:  5.00
Brief Description:  Installed rotor system
Installed the individual blades to the rotor hub on the ground. Lifted the blade/hub assembly with a fork lift and positioned over main rotor shaft. Inserted main teeter pin and secured shaft with fender washers. Lead lag adjustment and blade balancing had been performed earlier.
Rotor hub and blades
View from below
View from below
