JOHN'S WEB SITE
Date:  12-18-2011
Number of Hours:  4.00
Brief Description:  Fuel shut-off valve
Installed fuel shut-off valve in cabin floor. Andair makes an improved valve not supplied with the kit. I will use the valve supplied by Eagle R&D to drain the main rotor transmission .
Placed the fuel strainer at the lowest possible position in the ship. This will insure that water and any other contaminents will be isolated.
Planning on placing the fuel pump in this area as well. It wil be downstream of the fuel valve and strainer. I reversed the routing of the fuel flow from the plans. This allows fuel from the tanks to go directly to the shut-off valve prior to th strainer and pump. Being able to stop the fuel flow when checking the strainer will be a benefit.
Andair fuel valve
Andair fuel valve
Andair fuel strainer
