Started to wire the upper panel. Connected all of the instrument lights to a common ground. Used LEDS in tandem to serve as warning lights for- Starter on, Clutch engaged, Clutch dis-engaged and Low fuel. I am setting the aircraft up for night flying. Still have to wire post-lights for the Airspeed, Tach, Vertical speed and Altimeter.
