JOHN'S WEB SITE
Helicycle
Tip weights
Tapped each blade for three 1/4-20 size countersink set screws. Will need to file the heads of the screws to match the contour of the blades. Minimizing drag is critical on the outboard 10% of the rotor blade.
Drilled tip weights
Tip weights in place
F1 Rocket Evo Home
Helicycle Home
1065
Cabin Doors
Check-out and Airwor
Governor & RFI
Main Transmission
Rotor Blade
Swashplate
Swashplate
Tail Rotor
Trim Fins
Turbine engine
25
83
