JOHN'S WEB SITE
Helicycle
Electrical 6 gauge
Cut supplied 6 ga. wire to length and crimped and soldered ring terminals. Completed cables between the two batteries, the aux. start receptacle, starter solenoid and engine ground. Finished with two layers of shrink tubing.
Main switch
Starter relay
Primary engine Ground
F1 Rocket Evo Home
Helicycle Home
1065
Cabin Doors
Check-out and Airwor
Governor & RFI
Main Transmission
Rotor Blade
Swashplate
Swashplate
Tail Rotor
Trim Fins
Turbine engine
25
83
