Bent the steel drag link brackets to approximate the spacing needed for the rod ends. Per the video and plans eventually drilled the reamed the 3/16" bolt holes. A little tricky bisecting th angle of the rotor cord. Will need to borrow an end mill to account for the divergent angle of the brackets. Many builders have done this, though it is not addressed in the video.
