Made a bracket which is fastened to the forward aspect of the actuator motor. Used 1/4" longer socket head cap screws that connect jack-screw to the motor as a means of retention. Fabricated an .050 alum. arm to depress the switch when the clutch is full down (engaged).
Elected to not install the upper switch. Many builders say it is not needed and does not increase safety.
