JOHN'S WEB SITE
Helicycle
Tail rotor install
Installed Tail Rotor Gearbox after painting with "Robinson" Gray Imron. Used washers to shim the gearbox to line up with Tail rotor drive-shaft.
Purchased S.S. socket head cap screws to replace the ones supplied with the kit. They secure the tail rotor bearing plate.
Filled the TR gearbox with oil.
Final installed the TR scissors and slider
Safety wire
More safety wire
F1 Rocket Evo Home
Helicycle Home
1065
Cabin Doors
Check-out and Airwor
Governor & RFI
Main Transmission
Rotor Blade
Swashplate
Swashplate
Tail Rotor
Trim Fins
Turbine engine
25
83
