JOHN'S WEB SITE
Helicycle
Panel
Shaped 1/8" plywood to create accurate template for panel. The instrument pod is not symetrical so hand fitting is required.
Cut and fiberglassed five brackets which support the panel. Also bonded two longer brackets for the lower rectangular panel
Panel template
F1 Rocket Evo Home
Helicycle Home
1065
Cabin Doors
Check-out and Airwor
Governor & RFI
Main Transmission
Rotor Blade
Swashplate
Swashplate
Tail Rotor
Trim Fins
Turbine engine
25
83
