while reviewing the plans I realized the rear spar was doubled at the root and tappered to the tip. This woulld have then shortened the aft ribs. Too late. I do think it should be doubled since it transfers the forces from the the ailerons. I am laminating to the back of the rear spar and will cove it to save weight and since now it will be thicker than it needs to be.
